Originally Posted by Turbo
Looking for confirmation on a 4R100 replacement in a 2002 Ford E350 7.3L PSD. I assume I should be looking for a 99-02 4R100 4wd non-pto unit for a F250/F350.
Can anyone confirm?
Any suggestions on a trusted builder?
You can convert your 2wd tranny to a 4wd. You have to replace the main shaft and the tail section. If your thinking about buying a 4wd tranny and rebuilding it, might be cheaper to rebuild and convert the one you have already, plus you know it will connect back up just fine.
