Originally Posted by Turbo
Winnievan I'm in search of a dual stabilizer setup. If I buy a kit I might have a single 985-24-001. No promises.
What dual stabilizer brackets are folks using? Some brands I've seen.
Kelderman
BDS
RoughCountry
Superlift
I found some Fabtech Dirt Logic stabilizers on CL for really cheap and paired them up with a Rolling Big Power bracket I got on Amazon Warehouse for $99--which is the same as the Zone Offroad product. The RBP/Zone Offroad unit is definitely at the cheaper end of the spectrum -- but the bracket seemed pretty solid for the price point.
I was pretty stoked -- thought I had an equivalent of a $700 stabilizer system for a steal. Then I rebuilt those Dirt Logic shocks... and when I opened them up they were missing somethign -- they didn't have an Internal Floating Piston (IFP) -- I verified with Fabtech they weren't supposed to have one -- pretty insane for a product Fabtech sells for like $800+ new. So they're just really fancy emulsion shocks (i.e. the gas is mixed with the oil) which really aren't going to work well when mounted horizontally. Emulsion shocks only work properly when mounted vertically -- so with a dual stabilizer you really want an IFP to separate the gas from the fluid in this application.
If you don't know what an IFP is or why it matters in this application -- here's a good read from Carli:
https://carlisuspension.com/what-is-...ng-stabilizer/
So I finished the rebuild and and sold them for a small profit with the bracket kit and traded up to my Kelderman kit with the help of a Black Friyay sale. Many of the brackets look wimpy and there is a lot of force going on around a Dana 60, so I always had my eye on Kelderman given how the beef of their bracketry.
I learned alot during this process and my read is pretty much any of the super low end stuff is going to be junk both in terms of bracket and the included shocks -- skyjacker, rough country, superlift. But even some higher end stuff is going to be junk -- emulsion fabtech is going to be better than the rough country emulsion shocks -- but you want an IFP in this situation, IMO. The Bilstein 5100 is emulsion too -- so stay away from that in this application as well.
There are a ton of units out there -- but
I think this is how I thought about the various options while researching -- and this is only based on the bracketry not the included or recommended shocks:
High-end --
Keldermann :
https://kelderman.com/shop/2017-ford...ilizer-bracket
Ikon:
https://iconvehicledynamics.com/acce...tabilizer-kit/
Stryker #1:
https://strykerordesign.com/collecti...ing-stabilizer
Stryker #2:
Flight Fabrication (only lsted for 2017-2020 -- but I bet it'd work):
https://flightfabrications.com/2017-...tabilizer-kit/
PMF:
https://www.pmfsuspension.com/2005-2...-Kit_p_65.html
Medium:
BDS:
https://bds-suspension.com/product-d...fox%20steering
Zone Offroad:
https://zoneoffroad.com/products/dua...33411023667288
Low-end - Superlift, Rancho, Skyjacker, Procomp, Fabtech...
This is by no means exhaustive -- but that's my read on the market.
I think Kelderman, Flight Fabrication and Stryker 2.0 are the absolute best in this market -- but they are also the most $$$.
If you really want to step it up a notch -- you could pair a dual stabilizer with King or Carli IFP stabilizers -- or go with the Kelderman unit with the custom valved Falcon shocks.
I think there are a millions way to skin this cat -- but, frankly, I choose Kelderman because it is sturdy as all hell and doesn't use U-bolts. The omission of U-bolt was purely asthetic for me. I'm sure cheaper options are out there that would work great. It's also super easy to install on our vans since it goes underneath the tie-rod -- the other one I installed involved me poping the taper on the drag link to get it mounted -- the clearance seemed fine after installation but it does add another step.
As usually, YMMV -- but it does seem like there is a wide variety of steering stabilizers aimed at various price points in the market -- I personally think using IFP shocks/stabilizers in this application is preferable and your money will be better spent getting a solid bracket and pairing some good IFP shocks with it than dropping a bunch of money on the best bracket and then putting some Bilstein 5100 (emulsion) shocks on it.
