Member Karma, put this list together of some hard parts and prices. This info is on page 2 of this tread.
[QUOTE=karma;236431]Part Name Part# Price
2 Bump Stops DC3Z-3020-B $20.00
2 Radius Arms $100.00
2 Bump Stop Bracket 5C3Z-3A089-BA $20.00
2 Spring Retainer F2UZ-5A349-A $40.00
2 Spring Isolator E8UZ-5414-A $40.00
1 M20 Trac bar bolt W706345-S439 $40.50
1 M20 Track Bar nut W520117-S441 $10.00
5 Radius arm M18 nuts N807659-S441 $45.00
4 Bolt - Radius arm axle mount W709860-S439
2 Bolt - Radius arm rear mount N806967-S439 $16.00
2 Nut – lower spring perch mount W711430-S900 $21.00
2 Bolt – lower spring perch mount W500765-S439 $25.00
Carli Suspension Track Bar CS-FPRB-05 $345.00
2 Moog Sway Bar Links K80015 $46.00
2 Fox 2.0 Performance Series Smooth Body IFP Shock 980-24-677 $250.00
Coil Springs cc880s $92.49
2 ABS female connector (for van side wiring) Molex 34062-0027
4 Crimp terminal for ABS connector Molex 34083-2003
4 Wire seal for connector housing Delphi 184139-1
Brake hose, right DC3Z-2078-L $23.33
Brake hose, left DC3Z-2078-H $24.00
1 Stabilizer bar 8C2Z-5482-B
2 Stabilizer bar bushing E9TZ-5493-C $22.00
2 Stabilzer bar bracket 9C2Z-5486-A $55.00
Steering stabilzer bracket Ford F2UZ-3E652-A $55.00
Fox 2.0 Performance Series Smooth Body IFP Stabilizer 985-24-001 $156.00
MG Metal Works Brackets $2,000.00
4x4 Extension Housing 3C3Z-7A039-JC $129.00
4x4 Extension Housing gasket 3C3Z-7086-AA
Also, you don't have to get a different transmission, you can have yours converted (new main shaft and tail housing).
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
