02-09-2022, 10:13 AM
#531
Turbo, any idea when you might be attempting this?
According to fordpartsgiant.com the VSS sending unit for my 2002 van and the 2003 F350 is the same part number F85F9E731AB.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
02-10-2022, 03:32 PM
#532
That's a great question. Aiming for spring time. Van is put together and running, so would like to take it out on a few trips before tearing in to the diff ... again.
2002 E-350 7.3L PSD Sportsmobile Poptop
1992 E-150 4.9L Sportsmobile [sold]
02-18-2022, 09:38 AM
#533
I just finished my first 1k miles and I have to report that the van looks badass, feels right and drives great. This kit is awesome and thank you all for your contributions on here, very helpful.
More importantly, thank you Michael for the awesome kit and your support.
Fred
Camper, Powerstroke Fan
2005 Ford E350 4x4 6.0
02-18-2022, 01:54 PM
#534
VMC, thanks sending some positive feedback, always good to hear.
7.3
CCV high top
Denver, CO
02-19-2022, 12:03 AM
#535
Agree with lilnuts, always love hearing positive outcomes, especially these days!
A vehicle’s worth is not what you put into it, but what it put into you.
2019 F350 SuperCrew flatbed composite camper
2018 Transit 130WB MR EcoBoost (SOLD)
2010 E350 RB V10 Cargo "unicorn" (SOLD)
2007 E350 4x4 "VANdiana Jones"(SOLD)
02-23-2022, 09:32 AM
#536
vss trouble 4R100
This is my first post here, lots of great info.. wonder if anyone has run into the same issue I am having! I am working on a 2003 E 350 with 7.3 and 4R100. After swapping the super duty axles (2009) and having the trans converted to 4x4 it reads 50 mph at 10 to 15. get out on the road and speedo just goes wild right up to 80. The transmission is shifting in 2,3 od and maybe lock up.. tries to stall the engine at around 30 actual mph. My scanner also shows the speed why to high. Both speed sensors check out good in trans as well and rear diff sensor. I am wondering if there is a calibration for different ratio but one jump down in ratio dont seem like it would cause speedo to be that far off.Maybe the tooth count on the out put shaft ? I dont know of more than one output for the 4R100. spinning my wheels on this one! any input would be great!
02-23-2022, 10:30 AM
#537
Sounds like you don't have an Electronic Ratio Adapter installed or haven't modified the tone ring? There is a difference between the 2wd van output shaft tone ring and the 4wd shaft tone ring so the speed sensor signal needs to be modified to compensate for the differences.
Electronic Ratio Adapter (ERA)
This device is wired inline with the sensor to modify the signal.
02-23-2022, 11:12 AM
#538
Thanks for the reply! can I simply swap the tone ring or order on to match the 2wd?
02-23-2022, 11:29 AM
#539
If you click on the ERA link that MG posted it’ll show you the converter. Michael also clued in how to wire it up, “inline.”
I still don’t feel like my ERA is dialed in though. I’m on 35”s and my new axles have 4.10”s in them. The van still feels like it’s way too high on the rpm band and my speedo can be jumpy. I’ve had numerous vehicles with 4.88’s with both 35”s and 37”s that didn’t feel this wound up on the Highway. And by wound up, I mean the higher rpm’s.
02-23-2022, 11:30 AM
#540
the ERA is an easier solution than modifying the tone ring.
