Old 08-10-2022, 12:47 PM   #611
I‘m on the way to my shop who might have one laying around. Will be there today in ~45-60min.
Shoot me a pm and we share phone number to align
Old 08-10-2022, 02:33 PM   #612
Got it! Thanks for doing this!
The power of the internet is amazing!
Old 08-10-2022, 10:11 PM   #613
Mikerson's Avatar
Originally Posted by mgmetalworks View Post
Is anyone in the process of removing/converting their 4R75 trans (still in 2wd configuration) that could take a measurement for me?
I still have the old tail shaft and 2wd tail housing sitting on my workbench. Can take measurements of that if it’s of any help.
Took some pics before conversion next to a ruler. Maybe I can dig them up.
Mikerson is offline   Reply With Quote
Old 08-12-2022, 08:54 AM   #614
Total length ~29cm
Long seal ~2.5cm
Tail shaft behind seal ~2-3mm
Old 08-12-2022, 09:53 AM   #615
Total length ~29cm
Attachment 45141
Long seal ~2.5cm
Attachment 45142
This is perfect, thank you!
Old 08-15-2022, 11:28 PM   #616
Transfer case crossmember
First off, I'm extremely thankful for this tread! I have a 2012 extended with the 5.4..
I'm wondering how to tackle the crossmember?
I assume I should move it inside the frame rails and drop it down some??
silverhorse is offline   Reply With Quote
Old 08-16-2022, 07:43 AM   #617
skumancer's Avatar
I got mine done like this, plenty of protection and clearance!
I’ll get a couple more pictures for you later today!
skumancer is offline   Reply With Quote
Old 08-16-2022, 07:07 PM   #618
Thank you, @skumancer!
Couple of questions....Is the original tyranny mount insulator used and does it stay in the same location when you swap from the 2wd tailshaft to the 4wd intermediate housing?
Old 08-16-2022, 07:12 PM   #619
#8 pictured above
Old 08-16-2022, 07:36 PM   #620
skumancer's Avatar
#8 pictured above
Yes, you can keep the same insulator, but the placement of the crossmember is different. You’ll have to extend the crossmember while you don’t have the front axle brackets in place.
I did things in two parts: first modified the transmission, cut tank, attach transfer case, cut rear driveshaft, modify stock crossmember. That left the van drivable while having the 4x4 driveline in place.
Second step was to install the front axle. I made a temp crossmember because the stock one won’t fit on the 4R75E with MG’s brackets. Once the van was drivable again with the whole 4x4 drivetrain, I made the transmission crossmember.
