Originally Posted by RememberTheFallen
Edit: Emailed MG and he said he has not worked with the 2018+ axles so appears they may not work.
I know the front brackets are designed for 05-16 axles but are there reccomended years for a replacement Sterling 10.5" axle in the rear? Will a 2018 work?
Just found out that it will be $3300 to regear my 3.73 axles (with a rear Truetrac) so I think it would make more sense financially to try and find a set of 4.30 axles and sell these.
Yah -- seems there are some differences, but not sure what they are exactly. I know the Carli lists different track bars for 2005-2016 and 2017+... so it must be somewhat different in the front.
Honestly -- the rear would probably work -- they still using the 10.5 Sterling... but why risk it? Just get a 2016 or older and go for it -- deals are out there. You can find 4.30s with E-Lockers for sub-$1000. However-- try and find one with brakes and everything included -- it'll save you money in the long run unless it is REALLY inexpensive.
I got both my axles for what I'd consider steals... deals are out there -- pick a price you want to pay and ask the yard if they'd consider it -- you're much more likely to get a better deal by starting with a number rather than starting with "how much are you charging for that axle..."
