Originally Posted by VMCFred
I can't find VSS wire or the Neutral indicator wire to tap into.
I found part of the answer and just to share on here. In the 05-07 vans there are blunt cut wires in the engine bay that provide access to both the VSS and the transmission park/neutral wires.
For gas engines the wires/tags are:
VSS - AFT STD (Gray / Black)
Park/Neutral - PRK_NEU (Red / White)
Ford Diesel engines:
VSS - VSO (Gray / Black)
Park only - TRO_P (Yellow / White)
Neutral only - TRO-N2 (Red / White)
Park/Neutral - not available
My van is diesel and I'm assuming I can't simply tie the park and neutral wires together to get a combined Park/Neutral wire.
What have you all done with the diesel vans with torque shift for the park/neutral?
