Originally Posted by silverhorse
#8 pictured above
Yes, you can keep the same insulator, but the placement of the crossmember is different. You’ll have to extend the crossmember while you don’t have the front axle brackets in place.
I did things in two parts: first modified the transmission, cut tank, attach transfer case, cut rear driveshaft, modify stock crossmember. That left the van drivable while having the 4x4 driveline in place.
Second step was to install the front axle. I made a temp crossmember because the stock one won’t fit on the 4R75E with MG’s brackets. Once the van was drivable again with the whole 4x4 drivetrain, I made the transmission crossmember.
