Had the alignment done this morning not very happy right now.
The truck still has severe death wobble despite being aligned properly, all brackets welded as per instructions, brand new tires, brand new trac bar, brand new shocks, fox steering stabilizer, coil springs, isolators, etc....
Caster was set to 5 degrees as per the manufacturers recommendation, camber and toe were set to 2005 F-350 specs. I have checked and double checked everything and it still has the death wobble.
Once i realized it still had the death wobble i went home immediately, crawled underneath and gave each of the adjustable lower arms another turn to increase caster even more and it still has death wobble. I did this twice for a total of two full turns beyond 5 degrees with no success.
Im gonna take a day off from it because im worn out from it. This is a major problem, i didnt spend thousands of dollars and chop up my x-member to have a truck that is undrivable.
This weekend i will double check everything. Is it possible that the tracbar bracket is to weak and is flexing sideways causing death wobble? I was thinking about attaching another tracbar to the same bolt the axle tracbar uses at the frame and running it across to the frame on the opposite side to maybe help prevent any sideways give or flex in that bracket?
I dont have the swaybar on it yet because i am waiting on new links. But a swaybar isnt going to cure death wobble, that isnt what they are for. Does anyone have any ideas?
