Originally Posted by jimmyrig
I found this older thread - a couple of different shock part numbers were listed. Bilstein was one of them and these can be tuned at a later date. I have found Amazon seems to have Bilstein available through some suppliers unless its one of those Sorry we actually don't have that
What I am thinking-
Moog CC880S variable rate springs
Bistein 25-177480s
Will need to also address at some point - Rear, sway bar spacer
An Email from Bilstein to a fellow member suggested part#
*Front:**24-186018
Rear: 33-176840
But I cant determine if the front gives you the extra 1'' you need with the Moog Coils
Yes These will Work I installed the CC880's on my previous E350 and used the 24-186018 on both ends, front and rear. They are... (Compressed:13.590in. Extended 21.4.20in.) They're nearly the same length as the 33-176840 (Compressed: 13.66in. Extended: 21.65in.)
They're both 5100 series shocks with the 33-176840's having the shock valve body/the weight on the upper van body mount, unsprung. Whereas the 24-186018's have the valve body/weight on the lower sprung 'eye' end.
