Interesting about part numbers. The MOOG K80222 poly units I got from Felix (thank you!) worked perfectly in the 2000 Quigley V10. I had to cut the bushing sleeves to get those tack welded buggers out.
Used a piece of All Thread, nuts and large washers to press the poly bushings in most the way, then a BFH and a 2x4 to seat it the rest of the way. Worked well!
Note: if doing tie rods, it is way easier to deal with the swaybar bushings while the tie rods are out.
