Old 10-30-2021, 01:10 PM   #1
tedujam's Avatar
Replacement front Fox Shocks for a Ujoint Conversion
I need to get a new pair. Are these Fox shocks specifically tuned by/for Ujoint or can I just source them from anywhere?
Attached is the best photo I have of one
tedujam is offline   Reply With Quote
Old 10-30-2021, 03:57 PM   #2
I would email Chris at Ujoint.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 10-30-2021, 04:04 PM   #3
tedujam's Avatar
They were installed from a Ujoint kit, not at Ujoint, not sure if Chris would know.
Old 10-30-2021, 04:53 PM   #4
REF
REF's Avatar
Send a message via MSN to REF
I thought UJoint kits were all leaf springs front and rear? Clearly that’s a coil front end, could that have been from Agile? Although those don’t look like the progressive coils they usually spec out. You could probably get a properly valved set of Fox’s from Agile. See if there’s a part number on the ones you have
Old 10-30-2021, 05:21 PM   #5
Ujoint also sold coil spring kits made by MG Metalworks. They had some kind of falling out and Ujoint stopped selling coil kits.
OP - Try contacting MG Metalworks
karma is offline   Reply With Quote
Old 10-31-2021, 02:02 PM   #6
tedujam's Avatar
I don't have the original shocks anymore, they were replaced while I was on a trip this year with different shocks.
The guy I bought my E350 from said it was a Ujor conversion done by Green Tree Fab in Alaska maybe 8-9 years ago. I guess it's possible he was confused or lying, but every other bit of info he gave me about the van has checked out.
Home - Green Tree Fabrication | Alaska's Fabricators
Old 10-31-2021, 02:20 PM   #7
REF
REF's Avatar
As mentioned, most likely it’s an MG kit that was sold through Ujoint back then.
I’d get in touch with Agile for a complete set of tuned Fox shocks. You might have to pull a shock front/rear for measurements unless you can read the numbers and look them up.
Old 11-01-2021, 07:25 PM   #8
Pretty sure MG kits weren’t a thing yet 8-9 years ago.
2003 Astro AWD
2005 Tacoma Access cab 4x4
Old 11-02-2021, 09:11 AM   #9
As per the MGMetalworks Knowledge thread : https://www.sportsmobileforum.com/fo...tml#post297015
Some of us are running a known fox shock number. That kit looks pretty MG, having just done one my self. (More pictures of the radius/trailing arm brackets would pretty much close the case.)
If you are worried about custom valving, and they are fox, you could have them rebuilt. I would be tempted to swap on a new shock, see if its ok, and then if not, disassemble the old and new to compare valves.
As an FYI, I've some spare solutions on my build for suspension. I currently have a pair of some F250 front Bilstein shocks w/ 1500 miles on them that are about the right length that I would sell ya for $100. I got them in a set of 4, and only plan to use the rears.
Expensive custom shocks are currently ~4 months out.
desertsherpa is offline   Reply With Quote
Old 11-04-2021, 10:27 AM   #10
Vanzila's Avatar
Yes UJoint sold and installed them.. OP Contact U joint they will be able to give you the shock size they are not made for Ujoint they just buy and resell them.
Vanzila is offline   Reply With Quote
