Originally Posted by CObrew
I have an 06 E350 with the sportsmobile 4x4. The van has the gas v10. My fuel tank is starting to rust out and I cannot find a replacement or anyone willing to fix it. Does anyone know of a place I can buy a new tank that will fit the 4x4 conversion? I don't care if it is less capacity. I have tried agile, transfer flow and quigley. The only hope I have is that a quigley tank will fit. Transfer flow says they do not have and will not make a replacement and agile has one only for the diesel. The agile tank is much larger capacity than the Quigley which is appealing but I'd have to find someone to modify it to work with the venting and fuel pump for the gas engine. Any suggestions would be greatly appreciated.
If it's of interest, I have a brand new MTS 37gal poly tank (#4837) for sale. I don't know which 4x4 conversion you have so I'm not positive this tank will fit.
Here are the details;
1999-2010 Ford® E-350 Super Duty Cutaway Series 37 gallon rear/aft axle fuel tank. Tank includes our specifically designed sending unit gasket & stainless steel retaining rings for the sending unit and valves. Do NOT use the OEM sending unit gasket. This tank does NOT include a sending unit, EMS valve(s), EMS valve gasket(s), straps or skid-plate. Dimensions 30 1/2" x 24 3/4" x 13 3/8". Replaces # 2C2Z29002GA, 4C249K087DD and F7UA-9002-CD.
https://www.mtscompany.com/ford.htm
Originally Posted by Lilnuts2
35CC? Do you mean 37gal cab chassis(cutaway)? I think MG has mainly focused on the 55gal aft tanks for the EB vans.
