So what exactly has to be done to a slider door Econoline to clear the tires with a 6" u-joint conversion? and how hard is it? do they sell a bracket extension kit?
wow! Thanks for that that is an amazing wright up. I will check out the tailor made stuff and compare. Defiantly looks like it will take some fiddling. Your a legend.
Depending on your wheel/tire fitment you may only need a little bit. I extended mine 1" and it works fine on a 17x9 wheel (4.5bs with neg 12mm offset) and a 35x12.50-17 tire.
Scott
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
