Sorry for not following up on this sooner! Been busy going places and doing things.
I haven't posted a picture because I haven't taken one. However, the track bar looks just about like the stock one except that it has rod ends instead of rubber bushings. We used 1 1/2 inch D.O.M. and weldable tube ends. The rod ends, jam nuts, and misalignment bushings; all came from the local bearing house. Parts were about $275.00 not including the pinion shims and camber caster bushings which were $15.00 and $35.00 each respectively.
The growling that I alluded to in my last post is mostly gone once I remembered to disengage the front hubs
The whole deal, including labor and parts and alignment was about $550.00. Not cheap, but MUCH nicer to drive.
I have an aluminum Featherlite flatbed which I hauled to Ventura yesterday to pick up a 40's Delahaye which weighs at least 4000 # and it tracked and towed like a dream. Well worth the price of admission!
I have part #'s for the above parts, but not manufacturers, but can probably track down that information if someone is serious about replicating the process.
Bill
