Old 12-23-2020, 04:06 PM   #1
Spec'ing Timberline 4x4 Setup
I'm talking to Tim and Timberline Vans about my 4x4 conversion.
I'm considering going with Limited Slip in the rear and lockers (ARB?) up front.
My logic is the LSD in the rear will provide decent traction and control in slick conditions and the lockers up front can be used judiciously when I need help in a tight spot.
Wheels will be 17" Method Race Wheels with Bead Grip and 265/70R17 Hankook Dynapro AT tires (I love these tires).
My mission profile will be forest and mountain roads and routes such as the Enchanted Rockies Trail and Mojave Road. No Rubicon or rock crawling. We plan on driving to Alaska and the Pan American Highway.
I'm pretty ignorant on this stuff, so what are your thoughts?
Thanks!
~Terry
wander is offline   Reply With Quote
Old 12-23-2020, 04:49 PM   #2
Bellpilot's Avatar
If the Timberline Conversion has a 4” lift I would recommend 285/70r 17’s or 285/75r 17 for tire size. I think the 265’s would look a little small. I have the same axel setup in my van with the limited slip rear ended and the ARB locker up front and it works well.
2010 E350 6.0 4x4 EB 50 SMB
Old 12-23-2020, 04:51 PM   #3
Thanks, Bellpilot. Good to know.
~Terry
Old 12-23-2020, 09:55 PM   #4
DesertSMB's Avatar
I agree on the tire size. Our van has the same arrangement as far as traction control. Limited slip in the rear and ARB locker in the front. Ours is a fixed top and this has worked well for us.
Chris/Bev
2012 E350 EB50 V10 Cruiser Top
Sportsmobile 4WD Conversion
DesertSMB is offline   Reply With Quote
Old 12-24-2020, 07:01 AM   #5
Thanks for the affirmation, Chris/Bev. I'm feeling good about the setup.
~Terry
Old 12-24-2020, 09:24 AM   #6
WhitH's Avatar
100% concur on the tire size. Otherwise I like where you’re headed. That size should still fit in the stock spare location as well by the way.
Sold 2005 E350 Chateau
Old 12-24-2020, 03:06 PM   #7
deserteagle56's Avatar
With my 2007, a LT285/70R17 Toyo Open Country Mud Terrain WOULD NOT fit in the OEM spare tire location. I had to have a custom bumper/tire carrier built to carry a same-size spare. I still have the OEM spare tire up in the stock location so at least I have two spares. But since I went with the Toyos I haven't had one flat. Those are some tough, heavy, stiff-rubber tires!
Worshipper of Wild Country
deserteagle56 is offline   Reply With Quote
Old 12-24-2020, 03:44 PM   #8
WhitH's Avatar
Interesting, I guess it depends on the tire. I fit a Goodyear Duratrac and a BFG KO2 in the stock spot on my 05.
Old 12-24-2020, 05:20 PM   #9
I'll be installing an Aluminess rear bumper with swing-away tire mount, so that won't be an issue.
~Terry
Old 12-31-2020, 11:47 AM   #10
Steve Hunt's Avatar
Thanks!
Tim/Timberline did the 4x4 conversion on my 2008 E350. He pretty much focuses on 4" lift (I didn't want higher anyway) and I went with 275/70-18 at his recommendation. As far as the brand I wanted to favor on-road ride quality/quiet over off-road capability/rugged good look of say a BFG K02.
I went with Hankook DynaPro AT2. I'm a little under 8000lbs and down to 45 psi on the road. Seems to handle fine, no real increase in temp on my Roybi infared gun. I'm happy with the size choice and would most likely choose the same if doing it again. Strictly from a looks standpoint, from some angles, I wish they were a little bigger but again I doubt seriously if I would actually buy bigger. I'm real happy with the axles that Tim sourced for me...10.5 Sterling in the rear with factory electric locker and factory 4:30 gears (no need for spacers either). Dana 60 front 4:30 open diff.
Don't know about the spare tire area fit. i went with a U-Joint floor locker and rear skid plate. My future water tank will likely take up the remaining space on the skid plate. The remaining space for the tank is approx 30"x 14" x 12"
Steve
2019 Yeti SB130 Turq Race X01
Steve Hunt is offline   Reply With Quote
