Old 02-14-2021, 11:50 AM   #11
There are "in-line" speedometer correction modules for the Fseries. One made by Hypertech. They plug in to the instrument panel to "adjust" the input to the IPC without affecting any of the PCM or ABS stuff. It might be worth a call to Hypertech to see if they have something that could work for the Eseries.
Old 02-15-2021, 12:52 AM   #12
martinli's Avatar
@mgmetalworks yes Hypertech is usually the way to go.
But they do not offer speedo adjuster for E-Series of 2012 and up.
Also I did send them a request long time ago but never got an answer.
E350 - 2014 - 2WD
martinli is offline   Reply With Quote
Old 02-18-2021, 10:03 AM   #13
maybe these folks can help
Electronic Ratio Adapter (ERA)
Markmat is offline   Reply With Quote
Old 02-18-2021, 10:27 AM   #14
martinli's Avatar
@Markmat as I already wrote. Things like this will not work with newer model E-Series Vans.
E350 - 2014 - 2WD
Old 02-18-2021, 10:53 PM   #15
parisdakar's Avatar
I like how boywonder is thinking!
parisdakar
(bryon)
2010 Ford EB E350 4x4 6.0L with SMB Penthouse
parisdakar is offline   Reply With Quote
Old 02-19-2021, 12:27 AM   #16
martinli's Avatar
@parisdakarbut that doensn't help.
@boywonder mounting OEM tires is no option since the new bigger tires have to be in the German/EU documents.
E350 - 2014 - 2WD
Old 02-19-2021, 09:36 AM   #17
parisdakar's Avatar
martin: It has been a while since I have dealt with TUV issues.
Isn't it possible to get special waiver/documents from a TUV inspection station for limited production specialty builds/custom designs, or special parts required on non-homologen vehicles (for example, a specialized delivery truck configuration or a custom refrigeration van or such)?
parisdakar
(bryon)
