boywonder so you stil have got the problem?
10% off is what I assume to happen going from 265/75/16 to 285/75/16.
Currentl its 7% off.
Forscan is not a dealer tool. I know this tool very well. But there is no chance for my Van to adjust tire size with Forscan.
Changing gear ratio or modifying the diff speed sensor signal will not help.
This is what I first saw as plan B. But since the speed signal are taken directly form the wheels (ABS sensors) the diff ratio has got no influence to the resulting speedometer signal.
I need it to be homologated according to German rules ;-( that's the key problem.
