Originally Posted by kbeefy
If your swapping axles anyways, maybe you can put lower shock mounts on the axle to recover some of your shock travel. 2" of up travel is terrible!
Yep, I wouldn't do much 'testing' with your current set up, and would also wait to install the new axle before contemplating any adjustments.
Once it's in, jack up one side to see how far the diff drops - you'll want at least a little more travel than that so you don't end out using the shocks to suspend the diff prematurely, or you could consider attaching limiting straps (rear and/or front).
Once the diff is in then you can adjust for the sumo's and also measure what you'll need for shock travel. The sumo's are your new bump stops so you need to measure shock travel as if the sumo's would be compressed at least 3/4 of the way minimum since the blue Sumo's are more forgiving). Weight of the van & the performance characteristics of your leaf spring pack can/could play into the equation, as would a rear sway bar if you have one (unless you have quick disconnects that you'd be utilizing).
Normally you can get a
ruff idea of how much travel your shocks are currently handling by inspecting the shaft - the shinny area is an indication of how they're being exercised. The dirty part of the shaft pretty much reveals how much travel you still have available. ***If you haven't done any technical wheeling for a while then what you see now may grossly underrepresent your actual needs.
