Old 02-15-2016, 07:23 AM   #101
REF
REF's Avatar
Send a message via MSN to REF
^^^capn, with what wheels?
2003 Ford E-350 SMB RB-50
7.3L w/DP tuner & 4" exhaust
Quigley 4X4 (heavily modified)
CCV high profile insulated pop top
Old 02-19-2016, 08:38 AM   #102
Level 8 Tracker Pros with 285/70 17 BFG KO2s
jjuan is offline   Reply With Quote
Old 02-19-2016, 06:48 PM   #103
REF,
The wheels are Black Rock Yuma's. 17 x 8 with a 4.5 backspace. Happy with them except they scratch really easy when you use the lug wrench on them.
Old 02-19-2016, 06:57 PM   #104
Bellpilot's Avatar
I have BFG 315 70r 17's with American Racing Mojave wheels
2010 E350 6.0 4x4 EB 50 SMB
Old 02-20-2016, 08:17 AM   #105
REF
REF's Avatar
^^^^^steep hill! Great grip on those tires......
Old 02-20-2016, 08:35 AM   #106
Bellpilot's Avatar
I do live at the Cascade Mt. Range!
Old 02-20-2016, 08:44 AM   #107
Awesome rims! What dimensions and offset are you using?
"Life moves by pretty fast, if you don't stop and look around once in a while, you could miss it." -Ferris Bueller
lavolpe79 is offline   Reply With Quote
Old 02-20-2016, 09:57 AM   #108
REF
REF's Avatar
Looks like Tracker pro 8 lugs are avail in 16" 8X165(6.5) and 8X170
17's are only available in 8X165(6.5)
They also make a tracker wheel without the simulated bead lock in both 16"/17" in both bolt patterns.
http://www.discounttiredirect.com/di...cker&typ=Truck
http://www.discounttiredirect.com/di...ro+8&typ=Truck
Old 02-21-2016, 08:16 AM   #109
Yep level 8 Tracker Pro they are 17" with a 8x170 not sure why the website doesn't show the 8x170 but they have them -12mm offset I did get rub on the front but a little trimming took care of that
Old 02-22-2016, 10:49 AM   #110
Here is my wheel setup on my 4" lifted QuadVan. 17x8.5 Walker Evans street locks with Toyo E rated (80 psi) MT tires, 295/70R17 measuring 33.5". I went up from 285/70R17 Nittos that measured 33.0".
This necessitated a change to 4.56 (from 4.10's) to pull top gear consistently with my V10.
17" wheels to clear F450 brakes. Air bags out back to adjust ride height and compensate for pulling trailers. I did have to trim my front plastic valance for the 295's.
I will be going to Toyo Open Country R/T 295's next as I am below 50% on these tires.
The Toyo Mt's have been good tires.
My previous Nitto 285 tires would not stay balanced for some reason - I had to have them rebalanced several times...
Cheers
maxacceleration is offline   Reply With Quote
