Originally Posted by vandiesel
Are you full float dana 60? Any spacers? These wheels are 1/2 off right now! Can you show a side shot like Shenrie?
Stock Dana 60 semi-floater, 2" spacers/adapter (change 8 on 6.5 to 8 on 170). 2" brings the rear into the same track as front, so I assume same / very similar to Shenrie 10.5 sterling without any spacers
Here is an equivelent pic
But if you look at Shenrie wheel spec's vs mine.
17x9 / offset -12 / bs 4.53
17x8.5 / offset 0 / bs 4.75
Shenrie wheel face will stick out 18mm (3/4") further than mine. But once you put the same size tire on both sets of wheels, that will change again.
On my vehicle his wheels would not fit without further trimming. Here is how they look when I first put them on. (Had different wheels then, but same BS / offset). They fit pointing straight and no suspension compression.
Once you turn the wheel, and compress the suspension slightly, they rub. This is why I had to trim.
If I was to run Shenrie wheels, since they stick out slightly more, that would increase how far back the tire would be when the wheel is turned. That's why I say I'd have to trim more with Shenrie wheel size.
