Old 08-28-2020, 05:25 AM   #11
ya I tkink im going to go with the locker im sure the one time I actually need it it will make the extra money worth it. thanks
Itchy feet is offline   Reply With Quote
Old 08-30-2020, 10:27 AM   #12
Another data point: I've only got about 100 miles on my new Trutrac, but I've discovered that it chatters on hard turns, enough to rattle loose stuff. The installer (Randys ring and pinion) said I need to keep putting miles on until the 500 mile break in oil change, then switch to full synthetic. There is no adjustment on these, so all I can do is keep driving for now and hope it settles in.
Old 08-30-2020, 11:16 AM   #13
mk216v's Avatar
Great thread, just what I was needing to read up on, thanks all. Having had factory lockers (3 hydraulic in Mercedes G-Wagen, 2 electronic in Cayenne) and 1 ARB air in the rear of Vandiana Jones, I wanted to read up more on True Trac LSD (F350 has factory e-locker rear, but I was trying to decide to go with ARB air or True Trac LSD in front). Since the truck won't be a daily driver, and while we'll be driving in snow and such, we'll be doing so with true winter tires (probably Nokian Hakkapelita's) which will help with grip, so the times when we'll need the locker are more in non-winter offroad travels. I think I'll stick with ARB air for my front and report back...
A vehicle’s worth is not what you put into it, but what it put into you.
2019 F350 SuperCrew flatbed composite camper
2018 Transit 130WB MR EcoBoost (SOLD)
2010 E350 RB V10 Cargo "unicorn" (SOLD)
2007 E350 4x4 "VANdiana Jones"(SOLD)
mk216v is offline   Reply With Quote
Old 08-30-2020, 12:20 PM   #14
Selectable front and rear IF you can afford it.
If you do not have the budget for above install a mechanical locker in the rear and a selectable in the front.
I would not run mechanical lockers front and rear. Mechanical locker rear only.
Remember "Drive Fast, Turn Heads, Break Hearts!"
2001 Chevrolet Express 3500 Quigley 4WD ATF "Bomber Van"
1995 Chevrolet ASSTRO 4WD Quigley Custom Van
1994 Dodge B350 Sportsmobile Van
vintageracer is offline   Reply With Quote
Old 08-30-2020, 01:13 PM   #15
mk216v's Avatar
Tell us more...why no mechanical (ie helical/gear LSD) in front?
Old 08-30-2020, 01:37 PM   #16
"Broncohauler" and "Rememberthefallen" gave excellent explanations why a selectable locker in best in the front versus any mechanical locker in the front.
Old 08-30-2020, 01:51 PM   #17
mk216v's Avatar
Ok, wasn't sure if you had more helpful data/experience to provide.
I found deserteagle56's feedback very helpful as well.
Old 08-30-2020, 03:00 PM   #18
I went Eaton Truetrac front and Ox rear on my UJOR. Talked to Chris about it quite a bit and it has done everything and more.
Rocks, mud, sand, hill limbs, washouts... It has never even acted like it was going to get hung up.
He knows what he is doing.
TheWeezersDad is offline   Reply With Quote
Old 08-30-2020, 07:06 PM   #19
When my stock limited slip started to go, I had a TrueTrack installed on my 2wd standard length E150 Club Wagon. I researched the hell out of it.Here's a quote from the Eaton faq
" Q: What kind of oil should I use? Can I use synthetic? Do I need friction additive/modifier?
A: A quality petroleum/mineral based oil works best in the Truetrac units. We do not recommend synthetic oil. Friction additive/modifier is not required."
If the unit has friction modifier in it now, that is one thing associated with the kind of noise you are getting. I tend to go with the factory recommends.
You'll figure it out. Best of luck.
wilma is offline   Reply With Quote
Old 09-01-2020, 10:42 AM   #20
Yes, I read that too. It currently has the break in oil installed by the builder with no friction modifier. Since I only have about 100 miles on it, it's too soon to really tell, hopefully it will break in and quiet down in a few hundred or thousand miles. Thanks...........
Betsy
darryldickie
Moby
maptester
