Originally Posted by scummy
Everything I have read for the ford setup has the studs pressed into the rotor and then the rotor assembly slides onto the hub from the backside and engage the flange on the hub. With my rotor drilled out to 11/16 I can no longer press the studs into the holes. I can only imagine that I am way over thinking this. I will try to pull a tire today to get a few pictures. Thanks for your input boywonder
The studs don't press into the rotor........you have studs sticking out of the hub flange, correct? The rotor holes slide over the studs sticking out of the hub.....Why are you fooling around with studs/lugs?
You've drilled the holes in the rotor out to work with 8x170mm studs, correct?
....can you post a picture of your hub that's still attached to the van?
