Definitely Sterling 10.5" rear. Curious what made you decide on an OX locker vs ARB, one of the Eaton's, etc?
What brand of gears does UJOR use; Richmond, Yukon, Nitro? Having just re-geared my F350 with Yukon 4.88s then Nitro 4.88s (because Yukon whined like a mutha...Richmond is far worse), I'd highly suggest Nitro if you have a choice.
RSC brakes up front are the biggest, but it's unfortunate you have to pay such a large sum to get them due to the '99-04(?) front axle, vs using a '16+ front axle with larger OEM brakes and larger knuckles too.
BTW, love the cleanliness of your interior, very well done!
Originally Posted by MSD
Well with everything with vans that can be debated. Justin at Ujoint Colorado runs 37s on his 6” lift. But only recommends running BFG KOs.
I plan on doing the same when I wear out my Toyos moving up to 37s & not changing my lift or going up to 8”. An 8” lift is a bit much & doesn’t really make the van any more capable over an 6” lift...
After having both coil & leaf sprung 4x4 vans & i have driven every upfitters vans on the market. When I was at CCV I had the ability to take vans out for shake down drives (usually a30 to 35 mile drive) after build outs or pop tops. My preference is a Ujoint van over all others. Top 3 are Ujoint, timberline, CCV. You mileage my vary…
I don't want to start a tire debate, but aarcaris, do you research before you spring for BFG K0's or K02's; there are far better tires out there for less money, which are actually manufactured round (a shock I know, LOL) and thus don't have the BFG balance issues, nor the cupping issues that often occur.
I enjoyed my UJOR 6"/35s, but I was still new to Ford vans at that point. It improved going from Bilstein's to Fox 2.0" (so 2.5" would be even better if properly tuned), but the steering radius got to me. Best I've driven is an MG/ExpoVans coil conversion. Far more confidence-inspiring than an SMB. I would have liked to have driven an Agile TTB before they stopped production though.
Can someone remind me what an E250 with UJOR requires vs an E350?, as I don't see mention of it here. It's been awhile, but I remember Chris saying in an early video why an E350 (frame, etc) vs E250/150.
