Hey folks,
Just a few minor updates, but I figured some of you might find this stuff useful.
Floor liners:
I ordered the Husky floor liners for the front (PN 33251), and they fit fine. The material feels cheaper than the Weathertechs I usually order, and I think I prefer the Weathertech design overall just a little more. Will probably just keep the Huskys for now.
For the rear floor liners, the only "perfect fit" ones I could find were the Ford All-Weather mats, PN BC2Z-1613300-AD. These come as a set of 4: front driver, front passenger, and 2 long rectangular ones for the 2nd and 3rd row bench seats. I cannot for the life of me figure out how the two rectangular mats are supposed to be arranged. They are slightly different in width/length, but they do not fit "perfectly" in either position. Oh well, better than nothing and I'll probably just end up keeping these as well.
Passenger swivel install:
Ordered a swivel from blingmyrig.com, and overall this went very smoothly. Must've been unlucky because I managed to pull out one of the rear studs that bolt the seat base to the floor. No biggie, just replaced it and went about the installation. I also could not figure out how to cleanly disassemble the seatbelt tensioner connector, so I ended up accidentally damaging the connector. I just cut it out completely and replaced with
bullet connectors per 1der's suggestion in his video. Installed
1/2" split loom over the harness, but the bullet connectors didn't quite fit, so I put an additional length of 3/8" diameter split loom in that section just for aesthetics.
The connector PNs are E-2238-001 and E-2238-001, in case anybody wants to try and purchase new connectors and/or figure out how to disassemble them correctly. My guess is that the red plastic clips that snap into place (and presumably secure the terminals in the connector housing) are not intended to be easily removed.
Disconnecting the two mating connectors is fairly easy but may not be immediately intuitive to some: slide the red clip back (#1) and then depress the yellow tab (#2).
The damaged connector:
Rear Captain's Seats:
I bought an old, ripped, and non-matching rear captain's seat from my buddy for real cheap a few weeks ago. However, I happened to come across a post on the UJOR FB group for a pair of tan seats (the correct color) in mint condition. They were located all the way in Vermont, so I messaged the seller to see if he'd be willing to hold them until I was able to arrange a shipment through uShip. However, as it turns out, the seller's nephew just happened to be leaving Vermont that same morning and driving to a suburb just 15 minutes from Minneapolis! Couldn't have worked out better, so now I have a pristine set of captain's seats that I'll be installing. Just need to figure out the seatbelt buckle situation, as the seats came from a 2006 van and ours is a 2013. Might be able to pull the buckles from the original bench seat, but I haven't looked into it too much yet.
Transfer Case Trim Piece Issue:
I discovered that the t-case would not stay engaged in 4-low. I could shift into 4-low, but as soon as I started driving it would pop out of engagement. Turns out the T-case shifter trim piece was mounted offset by about 1", and was preventing the shift lever from fully engaging 4-low. An easy enough fix to move it to the correct position.
How the trim piece was originally positioned:
New trim piece location (you can see the outline of where it used to be):
Fuel spillage issue:
As I described in my previous post, I started having some auto-shutoff issues at the gas pump where the auto-shutoff would kick in, but a small amount of gas would splash out of the filler neck. I discovered that the rubber hose connecting the fill neck to the gas tank had a pretty severe kink in it, so I shortened the rubber hose a bit to alleviate the issue. Unclear if it solved the spillage issue yet, but I will report back.
For the T-case shifter and fuel spillage issues, I texted Justin to let him know just so he was able to react to the feedback on his future builds. However, he went as far as to offer to reimburse me for my time spent fixing the issue. It was such quick work that I declined his offer, but I thought that was a positive indicative of the type of business he's running. Of course, the most ideal situation would have been to not have these issues in the first place, but I suppose mistakes happen.
