There’s a hole under the black plastic step just inside the door on the drivers side. Iirc, the ebrake cable runs through it. I only noticed it when I took the plastic out for some reason and there was a ton of dirt underneath, so I poked around till I understood where the source was. Mine is an 03, so not sure they are all that way, but mine definitely has a big hole that water can just freely flow into it submerged.
