Originally Posted by arctictraveller
Interesting. I carry up to 15 gallons on top of the Aluminess box, in addition to a Honda generator, chain saw and a bunch of other stuff inside the box. I’ve never noticed the extra weight, although I do worry about the hinges, so I had additional gussets added and avoid opening the swing out when all three cans are full.
I've never weighed the contents of the box, suffice it to say it is full. I share your concern about the hinges and avoid opening the swing arm as much as possible with the extra 10 gallons of fuel on top, in addition I added the delron slides/supports shown in the picture below. The block does a great job of supporting the weight in the closed position and the slide makes closing the loaded assembly a lot easier.
Regarding feeling the additional weight, this is what caused me to upgrade to adjustable Fox shocks in the rear. Now anytime I carry extra weight in the back (fuel, minibike, heavily loaded trailer) I dial up the shocks to compensate. Great modification!
