Originally Posted by Vndlfsn
This is super helpful! We’ve made an offer on a 2013 4 x 2 sprinter with a D5 espar heater.
How exactly do you use the heater to keep the coolant and engine block warm? Do you run it overnight?
For the auxiliary heater there is an interface in the dashboard controls that you can use to set a timer for it to turn on at a certain hour. So you could program it and have it running to pre-warm your coolant in the morning. You should be able to locate a copy of the 2013 Sprinter manual online so you can see how this dashboard interface works.
I also opted for their rather expensive heater remote control which allows me to turn the heater on while still in my cozy home. I did read that this remote is no longer available though, for whatever reason, so you’d need to program the dashboard timer or seek out a 3rd party solution for remote starting the heater.
Once started, the heater will only run for a set period of time and can only be restarted a limited number of times before you have to start the van’s engine; likely to guard against depleting your starter battery. The heater will also not run if the ambient temperature is above 40F. I read this limitation was put in place to placate US government concerns about emissions from the diesel heater.
