Old 09-29-2024, 06:08 PM   #1
Double fuses?
I noticed tonight while becoming acquainted with the fuse box in the left side of the driver’s footwell that there are two fuse locations with wires attached to a permanent fuse with two fuses next to each other inserted on the front.
Anybody know why of how this works?
Vndlfsn is online now   Reply With Quote
Old 09-29-2024, 07:16 PM   #2
Are you talking about something like this?
Old 09-29-2024, 07:59 PM   #3
That’s the one! There are two I see. I was thinking maybe the function of the fuse is so critical that they have them daisychained in case one blows there’s another one in the path?
Old 09-29-2024, 08:27 PM   #4
Ok so it looks like these are called expandable circuits and I wonder if they support some part of the SMB buildout.
Old 09-29-2024, 08:27 PM   #5
The_Vermonster's Avatar
That sounds like a tap a fuse. One of the fuses protects the OEM circuit and the other fuse protects the wire coming off the device. It's a cheap and lazy way to add a circuit for something. It could be a radio, off road lights, or other things.
The_Vermonster is offline   Reply With Quote
Old 10-01-2024, 08:37 AM   #6
Nailed it.
kbeefy is offline   Reply With Quote
Old 10-01-2024, 08:48 AM   #7
Thanks everybody, that makes perfect sense to me. There are a number of aftermarket items on the van including Rigid LEDs mounted on the back of the penthouse, a back up sensor, and an aftermarket alarm system.
Malbec
brushogger
97 Eco
MTDave
