In Post #690 on page 69 I showed the repair I made to the broken bracket that holds the lower bump stop curved block in place. In that post I included a picture of the Sumo Spring orientation, but to get it aligned properly I had to adjust the attachment with that side of the van supported by a jack stand, making the assumption that my bracket repair had moved the lower bump stop curved block a bit.
The more I thought about it the more I thought that something was off. I went back under the van and took this picture of the bump stop orientation on the other side of the van with all four wheels on the ground.
This led me to take this picture. Comparing it to other pictures from the past I came to the conclusion that the wheel had moved back in the wheel well.
Following this I had good conversations with both Mark Hesser of Van Compass and John Brindle of Agile, both excellent resources.
The original MB design for the 4wd vans includes a 3" tall lift block under the rear springs. You can see it in this picture that shows the addition of the Van Compass Spring Pack to the original springs.
Flint is heavy, with the rear axle weighing in at 5,260 lbs. (MB GAWR is 5,360 lbs.) What I believe happened is that over time the rear springs settled and moved the rear axle back a bit in the process; amplified by the weight of the van, our bouncing the van around off road, and the effect of the lift block.
The simple solution would have been to remove the Sumo Springs and replace them with the factory bump stops, thus eliminating the added non-aligned contact against the lower bump stop curved block. I'm convinced this would have been fine, but I'm also convinced it would have gnawed away at me...
What I did instead was to replace the springs and lift blocks with a set of Agile's 5,400 lbs. rear leaf springs. As John told me, being within 300 lbs. of the spring design value is the "sweet spot" and at 5,260 lbs. Flint was right there.
I had the springs shipped to CAtuned Off-Road's shop in North Highlands (they are both a Van Compass and an Agile installer and a good shop to do business with in Northern CA, ask for Max) where the springs were installed, here they are in place:
And here is the weight rating sticker on the top of the springs, uncovered by me after it was taped over by a thoughtful person while in transit...
And here is a comparison picture of the wheel in the wheel well when the work was complete.
I can tell no difference in how the van handles or rides with the change. I have removed the Sumo Springs and gone back to the factory bump stops. I believe the picture above shows the wheel better centered in the wheel well and I am happy with the result. This change was made with 52k+ miles on the van, check in with me at 100k and we will see how it is holding up!
