Old 09-13-2022, 02:38 PM   #1
Gfi
Can a bad GFI keep outside electricity from powering the van. 2006 Dodge sprinter 2500
crisk is offline   Reply With Quote
Old 09-13-2022, 09:13 PM   #2
With my SMB build if the GFI power outlet inside the van trips, the other outlets won't work either. Does the test switch work? You can test it with a meter if you are qualified or feel comfortable working with AC voltages.
Old 09-14-2022, 12:50 AM   #3
Disconnect the gfi and retest your shore power. Not familiar with your system but if the gfi has a major short it could possibly keep your system from being operational.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 09-14-2022, 04:55 AM   #4
BrianW's Avatar
Yes, it will shut off all the other outlets too. When I bought my first SMB the seller gave me a big discount because the AC electric system wasn’t working. When I got it home and started looking into it all I had to do was reset the GFI button and everything worked fine! [emoji119]
Old 09-15-2022, 12:36 PM   #5
gahamby's Avatar
On my rig the GFI outlet had the battery charger plugged into it. I can't remember if the load side also fed the 110VAC loads. Mine went bad and I had to replace it.
'07 GMC 2500 6.0
