With my SMB build if the GFI power outlet inside the van trips, the other outlets won't work either. Does the test switch work? You can test it with a meter if you are qualified or feel comfortable working with AC voltages.
Disconnect the gfi and retest your shore power. Not familiar with your system but if the gfi has a major short it could possibly keep your system from being operational.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Yes, it will shut off all the other outlets too. When I bought my first SMB the seller gave me a big discount because the AC electric system wasn’t working. When I got it home and started looking into it all I had to do was reset the GFI button and everything worked fine! [emoji119]
On my rig the GFI outlet had the battery charger plugged into it. I can't remember if the load side also fed the 110VAC loads. Mine went bad and I had to replace it.
