RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-14-2020, 03:16 PM   #41
Otter's Avatar
Sounds like it’ll work out just fine with that extra unistrut. I bought a MaxxFan yesterday. Now for the hole in the poptop!
Old 02-14-2020, 07:14 PM   #42
sbgrimm's Avatar
With your skills I'm sure you're up the the task. Personally, I'm glad I left that to the trained professionals at Colorado CamperVan!
Bardo
2005 RB-50 5.4L V8 E250 "Blanca"
sbgrimm is offline   Reply With Quote
Old 02-29-2020, 12:29 AM   #43
sbgrimm's Avatar
Otter, I just got around to finally fitting my Yakima roof bars to the CCV unistrut. As you can see in the photo, the bar is just shy of clearing the MaxxAir fan. I placed the Unistrut shim in the photo to show how much higher the bar could be if that were used. It works out to 1 5/8" higher with the shim.
I'm pretty happy I don't seem to need the shim. The top of the crossbar is about 3/4" above the top of the fan. The bars do flex a bit with the weight of the raft frame, so I'll have to keep a close eye on that when I load. Also have to remember to not use the Maxxair fan with gear on the roof!
Bardo
Old 03-01-2020, 12:41 AM   #44
Otter's Avatar
Whoo hoo, Bardo, you made it! Looking at that extra unistrut shim, though, it seems that would have been fine, too. Either way, you’re in the clear. Cool! I’m waiting for someone to help me with the hole-cutting for my fan. My confidence is low on this one. Well, actually, fear.
Old 05-26-2020, 07:17 PM   #45
Flyview's Avatar
I'd really like to do this to my pop-top too! Definitely not for the faint of heart. I'd like to put mine above the stove, so just behind the pop-top handles and pad at the front. How does one make sure there are no wires or other structural beams you should not be cutting through?
I have a EB pop-top from 92 and it is not the strongest. It visibly sags down at the front and rear close to the bolts. I re-did the bolts with the ones made and sold by @Gooseberry and raptor lined it a couple of years ago. Will cutting this hole and accessing some of the wires in the top for power be possible without removing the top bolts? i.e. removing the headliner wood without removing the top bolts again?
Full time vanlifer in my SMB.
@man.and.van on Instagram.
Flyview is offline   Reply With Quote
Old 05-26-2020, 07:59 PM   #46
We do make adapters for pop tops. They will help reinforce the area where the vent is located and also conform to the curvature. Plus help make sure you cut the hole right.
All the best,
Hein
DIYvan
hein is offline   Reply With Quote
Old 05-26-2020, 11:22 PM   #47
Otter's Avatar
All the best,
Hein
DIYvan
Hi Hein. Do you have something I should consider using to help nstall the Maxxair Fan in my CCV, on a 2014 E350?
Old 05-26-2020, 11:34 PM   #48
We can likely make an adapter for you. Please send a photo of the desired location of the vent to my phone so I can help.
All the best,
Hein
DIYvan
541 490 5098
Old 05-26-2020, 11:36 PM   #49
Otter's Avatar
All the best,
Hein
DIYvan
541 490 5098
Thanks, Hein, will take and send a couple of photos tomorrow.
Old 05-28-2020, 12:25 PM   #50
BrianW's Avatar
All the best,
Hein
DIYvan
541 490 5098
@Hein I'm looking at putting a Maxxair in my SMB PH top, too. My top is flat (not ribbed)... what would your adapter do to help the install? Reinforce the cutout or something? Do you have a photo?
