We just came back from about 3 weeks in Texas, NM, and Arizona. The 2.7 was so noisy that we just turned it off at night and quit trying to keep things in it that would spoil. After reading these posts, I decided to take a stab at improving the noise. I removed the fridge, added some foam insulation strips to the rails that it sits on to dampen any vibrations through the floor:
Then I added some of the same stuff on front of the cabinet where the fridge screws to the cabinet to dampen any vibrations there:
Finally, I taped some reflectix to the sides of the interior of the cabinet:
I also noticed that the cabinet hanger bracket on the right side had an aircraft nut that was touching the side of the fridge, so I reversed it so the nut was on the outside of the cabinet (think Jage mentioned doing this also).
Bottom line, maybe not purr-fect, but much better.
