Old 10-05-2017, 04:01 PM   #21
RandallDee's Avatar
Just thought I would add another vendor to that list. I have used Van Haus in Vancouver, WA for some work and have seen first hand the work that was going on with several vans in the shop while I was there. I think they do nice work.
2023 Transit AWD w/ Van Haus build.
73 BMW 2002 O=00=O
RandallDee is offline   Reply With Quote
Old 10-07-2017, 01:06 PM   #22
Backcountryguy's Avatar
Agile Offroad Post-conversion Work
After several conversations with different outfits I decided to have all the post-conversion work completed at Agile Offroad. I've been pleased with the conversations I've had with John Brindle and Jesus Hernandez. The suspension work in particular has generated great conversations. I admit also that the post-conversion work being completed by one upfitter lines up with our plans for a trip to Joshua Tree and ski area tour on the way north just before I need to head back to sea for work.
I'll share the comprehensive work list below.
Item: 2017 Sprinter 4wd 2500 Sportsmobile 144
Sprinter Wheel Spacer & Stud kit, PR. 6x130mm x 14MM, Made in U.S.A.
$399.98
4WD Sprinter Front Coil Assist Kit w/coil, Made in the U.S.A.
$599.99
U-Bolt, Sprinter 2/4wd, 75MM x 180mm Ea., Made in U.S.A.
$99.96
4WD 2500 Sprinter Custom Rear spring, Made in the U.S.A.
$1199.99
Labor to Install RIP Kit on 2/4WD Sprinter*
$680.00
GOR 26148SBC, Short Lug Nut, Black, 14mm x 1.5 Spline
$87.25
1921SD-KEY Gorrila Lug Key, Small Spline Key
$9.99
WAR 92815, ZEON 10-S Platinum, Warn Winch
$1749.99
AOR 292017, Hidden winch plate, Sprinter 4x4
$989.99
Factor 55 FlatLink, Grey, 00050-06
$139.99
Labor - AO Sprinter Hidden Winch Install*
$650.00
RIG48203, A-Series LED Light,
$110.00
Sprinter20, Fuel Tank, Sprinter, Wheel Well Fill
$1195.00
Labor - General*
Install Aux Fuel Tank
$480.00
Skid plate, MERCEDES 4X4 SPRINTER ENGINE SKID PLAT
$650.00
Skid plate, MERCEDES 4X4 SPRINTER FUEL TANK SKID P
$700.00
Skid plate, MERCEDES 4X4 SPRINTER TRANSMISSION/TRA
$450.00
Labor - General*
Install Skid Plates
$150.00
Agile tuned Fox shock, 986-24-072-0 V4, 2.0, IFP, 8.1" Travel V4 Valving
$279.90Subtotal$10622.03Total Tax$671.31Total$11293.34
Backcountryguy is offline   Reply With Quote
Old 10-07-2017, 01:50 PM   #23
Fitz's Avatar
Feels good to decide, doesn’t it? Great list, I am sure you will be happy.
Question: I see you are adding the wheel spacers, what wheel/tire combo are you planning on installing?
KN6BJX
Old 10-07-2017, 02:33 PM   #24
Fitz,
Still up in the air on that, although currently the SMB build is for 265/70-17 KO2s. The spacers added by Agile Offroad for another combination in their estimate but may not be part of the work.
I have 265/70R17 A/T tires on my TRD Pro 4Runner on 17-in rims, like them quite a bit.
Even though we ordered wheels in our production at SMB West we may decide to take the stock configuration down to Agile and have them do the retrofit.
As part of the overall configuration going forward we will put studded tires on for winter ski area use down the road.
I asked Agile to add all they thought might be needed for the work, with the idea we will perhaps take things off but won't add.
Old 10-07-2017, 05:22 PM   #25
It does.bring up a good discussion topic. I reached out to Agile on their recommended configuration for tires/rims based on their RIP.
Old 10-07-2017, 06:22 PM   #26
Roam Built's wheels can be ordered with a custom offset so you don't need spacers. I believe they're 800 a wheel.
Wrinkledpants is offline   Reply With Quote
Old 10-07-2017, 06:28 PM   #27
Wrinkledpants, Great information, thanks. I'll research Roam.
Old 10-07-2017, 08:39 PM   #28
Fitz's Avatar
The topic of tires and wheels for a Sprinter build may be a good one to start a new thread on.
I have Method Wheels with BFG KO2 265-70R17 (31.6"x10.43") tires, a fairly common option with the current Sprinter 4wd’s.
There are several threads, both here and on other forums, where BFG KO2 285’s have been fitted and seem to run ok with front wheel-well plastic trimming required.
With my 265’s the measured clearance from the tire to the stock strut is 0.36”, just a bit less than the 0.40” required by calculation. This measurement is to the plastic strut cover and I am confident that the cover could be trimmed or worn away, I would be curious to get direct feedback from those running BFG KO2 285’s. Where do they rub?
I have seen plenty of threads discussing BFG KO2 265’s and BFG KO2 285’s, but never have I seen anything about BFG KO2 275’s. From what I can see, the 275’s may represent the largest tire size that can be easily run without adding the (very nice) Van Compass 2” Lift kit which gets you up to 315’s.
I have an Aluminess front bumper which adds clearance to the front over the stock bumper. I have just under 20k on my BKG KO2 265’s and they are wearing GREAT, but I think I will move to the 275’s when the time comes. Any comments?
For reference:
Stock 245/75/16’s - Diameter = 30.5”, Width = 9.6”
BFG KO2 265’s - Diameter = 31.6”, Width = 10.4”
BFG KO2 275’s - Diameter = 32.2”, Width = 10.8”
BFG KO2 285’s - Diameter = 32.7”, Width = 11.2”
Looking for feedback!
KN6BJX
Old 10-08-2017, 01:02 PM   #29
Originally Posted by Jsweezy View Post
That's not a jab, thats just truth.
Just googled sled hockey,wow! Very cool
Zappo is offline   Reply With Quote
Old 10-09-2017, 12:09 PM   #30
Fitz, Agile Offroad uses a 275/70/17 tire. I think I'll go with BFG A/T in that size.
Dusty
capnkurt
Moby
new2tx
