Old 05-13-2022, 10:29 AM   #1
92 high top wax or polish
I have a 92 fixed high top. Oxidized and i want to seal and preserve it. Rubbing compund? One of the gel coat products? Thanks Henry
acudoc is offline   Reply With Quote
Old 05-13-2022, 10:47 AM   #2
I recently polished up a 20 year old high top (also did my sailboat). You're probably going to need a heavy cutting compound for the first 1 or 2 passes. 3M makes a popular one - there are many others. I also found that polishing by hand is just not enough power. I bought a used rotary buffer/polisher and got pretty good results. Even then, I don't think completely new looking gelcoat is possible. But, you can get pretty close.
Old 05-14-2022, 06:42 AM   #3
Depending on how bad it is (pictures?) sanding first.
1.000 Grit
2.000 Grit
Buffing
And then 3Ms Perfect it 3-step polish.
Don’t use a regular buffer, go for a forced random orbit like this one at Harbor Freight. Have mine for 3 years, polished 5-6 cars + my Van from the base up.
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
