Old 07-15-2021, 08:59 AM   #11
Drape a double ended plumb-bob across the hood, and measure from each string to the tire sidewall??
Drape a longer double ended plumb-bob across the roof in the back and measure to rear sidewalls??
just thinking out loud.....
Old 07-15-2021, 09:31 AM   #12
VMCFred's Avatar
Originally Posted by 1der View Post
Maybe using the pinch seams on the body measuring to a point on the frame? Of course assumes frame is square.
Most of the times I have seen the "crab" visual it looks like the frame to axles mounting is askew.
I will try that thanks.
“Crab” effect is the best way to describe it.
VMCFred is offline   Reply With Quote
Old 07-15-2021, 12:33 PM   #13
I've seen too many "sidewinders" while I've travelled in my previous vans -- they make my vision lopsided traveling behind them and I think I too am sidewinding ! -- can't wait to pass them and get back to normal !
Old 07-19-2021, 10:17 AM   #14
The ideas posted suggesting finding points that are present on both sides of the body and moving the body where those measurements are pretty much equal. Naturally I'd first install the bushings and mounting bolts first, snug them down when you're satisfied the body is resting where you believe and see it's centered.
Old 07-22-2021, 11:24 AM   #15
Google ford body builder for you year van .. it will show detailed info on frame measurements.. if you cant find it I can send you a link when I get home .. good luck
Brianracedesert is offline   Reply With Quote
