Chassis Air Conditioning Pressures
Hi,
I have a Sportsmobile built in 1998 on a 1998 Ford E250 (5.4L) by the Fresno location. It has the Starcool system.
When the engine is under load, the van a/c system cooling drops off (not the Starcool) and blows warm air. I’ve had mechanics look at it, but they aren’t sure what pressure at which to charge the system since it apparently is connected to the Starcool system - they’re afraid of overcharging.
At what pressure should the van a/c system be charged? Is there a separate charge location for the Starcool system and, if so, where is that port?
Thank you.
~Terry
