Old 11-25-2022, 10:53 PM   #1
evy
evy's Avatar
Coolant/heater lines question (see video)
In my van conversion I want to add a Kuuma water heater that uses the coolant lines to heat the water (heat exchanger) and I'm not sure where to cut the existing lines to add Tees + valves and the new lines.
I have to find a Supply and a Return line.
Here's a short video I made with a view from the doghouse:
https://youtu.be/Kv4_2sK8BtI
Thank you for any help!
DIY conversion build, extended 2010 Ford 5.4L E250 + high top, from Montreal Canada, new to all this so please be patient and clear with me (never built or camped in a van yet)
evy is offline   Reply With Quote
Old 11-26-2022, 07:20 AM   #2
Asked and answered on FTE!
Old 11-26-2022, 07:21 AM   #3
Does your van have rear heat/air? If so it's very easy. Tap the lines under the van close to where you want your unit mounted.
Old 11-26-2022, 10:02 AM   #4
What Scotty said.... And if you don't have rear factory heat, you can buy the tee assemblies from RockAuto or NAPA, and extend your own hoses from there.
Old 11-27-2022, 07:30 AM   #5
What is FTE?
hogasm is offline   Reply With Quote
Old 11-27-2022, 07:39 AM   #6
Originally Posted by hogasm View Post
What is FTE?
Ford Truck Enthusiasts: https://www.ford-trucks.com/forums/1...see-video.html
Old 12-02-2022, 06:08 AM   #7
SMB installed such tees for a heat exchanger on our unit. The tee did not seem to have torque/stress imposed on it by the hose, however, after the second plastic one failed, I replaced it with a metal one. I suggest the message is to use a high quality metal tee and mount it such that it is not exposed to stresses or undue vibration.
maurshir is offline   Reply With Quote
