Old 05-08-2024, 03:23 AM   #1
Differneces between e350 superduty xlt and e350 xl
Hey yall so i got a 98 e350xlt superduty for just the body to do a body swap onto a better condition chasis from an 98 e350xlt after monkeying around i got the superduty to run. My question is, is there “upgraded” or better quality parts on the superduty i should also swap?
Baddogg is offline   Reply With Quote
Old 05-08-2024, 05:03 AM   #2
Check the door placard to see if the GCWRs are the same or not. That’s really what matters vs badging. There is a frame difference between the 8,600# and 9,100# variants. The 9,100-9,500# variants have the same fame but slightly different spring rates.
Old 05-12-2024, 11:01 AM   #3
it's a 16 year old van and depending on how it was used the springs won't be a value you're going to need "New" springs regardless.
fordsarefun is offline   Reply With Quote
Old 05-14-2024, 06:00 PM   #4
SierraHawk's Avatar
Tags
Baddog: Just do not lose the tags off the rear diff.
SierraHawk is offline   Reply With Quote
Tags
e350 superduty e350
