Old 06-20-2024, 06:24 AM   #1
keytothestone's Avatar
Do all EBs sagg a little?
Do all EBs e series that are camper converted sagg in the rear? Mine has always had a rear sagg. It's not like my cargo is some heavy equipment. The bumper does have a wheel carrier , box and bicycles. I've added 2 leafs in couple yrs ago at Standen in Canada. Still is little droppy. Saw a EB listed here for sale SMB and it had a little sagg. So is this just the way it is?
keytothestone is offline   Reply With Quote
Old 06-20-2024, 07:30 AM   #2
I would say yes on all vans where the owner hasn't worked to overcome it. It's just a lot of weight behind the rear axle if there's anything at all in the van.
Old 06-20-2024, 07:33 AM   #3
1der's Avatar
The way to measure if the rear is truly low is measuring from ground to pinch seam just behind front tires and just forward of the rear tires. If rear measures less then your rear springs might be toast or you need a bit taller lift block between springs and axle. EB's do lot have to be droopy, although the body lines kind of make it look that way sometimes.
Our 2002 EB was very even (loaded) on its original rear spring pack+add a leaf+ helper + 2.75 block. That is with an Agile TTB which raises the front end about 3". Almost any solid front axle conversion is at least 4" lift at front.
We had to replace our rear springs in March this year due to one of the leafs cracking. (Turns out both sides had cracks) We went with the HD General Springs replacements and kept the lift block. The new springs actually raised the rear by nearly an inch vs the front. I did not want to mess around with a custom spring pack as I really like the tide and handling we had on the original configuration. I have read far too many posts of the nightmares people had with custom arched spring packs being too stiff, too tall, etc.
If your spring pack is old, then a new rear spring pack will help restore the even stance. If you have a lift block, check the height. Blocks are available up to about 3".
Since you are looking to make the move to FF rear, this the time to change the springs and address the droop ( if you really have one after measurement) Definitely save the add a leaf / helper that was added to the spring pack, those can be reused. You have to make sure it is saved. I did not remember to ask and my add a leaf and helper were tossed.
Old 06-20-2024, 09:54 AM   #4
Twoxentrix's Avatar
Rear Air bags can help - I’m about half inch lower in the rear with no air, 40-45psi get me about 1/2” higher than the front. They really come in handy when you’re traveling slalom type roads, feels like a sports car when I set them to 60+.
Rear sway bar enhances the handling characteristics of you don’t already have one.
Old 06-20-2024, 02:32 PM   #5
BrianW's Avatar
I had rear airbags on my 1998 SMB and found them to be too much of a hassle. Replaced my stock sagging springs with a 5-leaf pack from ATS (not really "custom" like Deavers) for around $600 or so. Made a big difference in both stance and handling. My current 2011 SMB sags a bit, but not enough that I worry about it. As Twoxentrix says, a rear sway bar makes a huge improvement in handling for the EB vans. Even on my old 1998, the new rear springs, Bilstein shocks, and sway bar made it really easy to drive, even on the highway and twisty roads. (Attached pic of the 1998 shows it after the spring upgrade.) See before and after pics on this post I did on the Ford Trucks Forum: https://www.ford-trucks.com/forums/1...on-review.html
Old 06-20-2024, 10:53 PM   #6
bigriver's Avatar
Yeah... No. Bought our 2003 EB50 7.3 Quigley new from SMB west. No sag, 200K, 10,200 lb. and no rear leaf upgrade. Maybe just lucky?
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 06-21-2024, 10:38 AM   #7
rear airbags with leaf springs? where and how did you mount them? My RB SMB sits 2" low in back and its either replace the original leaf pack or add airbags. Don't the bags make the ride pretty stiff? And what about off road, off camber driving with bags? The van has a 6" Weldtec lift, so front coils and rear leafs.
Beaky is offline   Reply With Quote
Old 06-21-2024, 10:42 AM   #8
1der's Avatar
Or add blocks or taller blocks if that solution has not been used up.
General Spring makes some nice spring packs for our vans. Standard and heavy duty.
Old 06-21-2024, 11:47 AM   #9
deserteagle56's Avatar
Mine is NOT the Sportsmobile conversion...just the short E350 converted to 4x4 by Quigley. I haul either a motorcycle or quad inside so my camping gear has to hang on the walls. But even empty the rear of the van (damn, 17 years old now!) sags a bit. It does have a custom rear bumper with gas can and tire carriers mounted to it which add some weight.
I take the van into some pretty rugged back country so one of these days I may put a full floater and custom springs under the back.
Worshipper of Wild Country
deserteagle56 is offline   Reply With Quote
Old 06-24-2024, 06:51 AM   #10
Thanks for all the feed back! If I can get the FF down the plan was to do new springs. 1der you mention General Sprongs. The outfit out of KC? I was looking into those prior to this thread. So sounds like you are happy with them? I ordered some sumo springs the rubber deals. When I was about to install didn't seem like they would help. Didn't even seem like where the placement was would hit to make any difference. I'll have to look when I get back to the van how tall my lift block are. That might be something I could improve? 1der any particular CR at general you recommend? Thanks!
The Yeti
TexGX
MoMo
skyrat
