Originally Posted by 1der
That video takes the long way around properly installing what's now called "plus nuts". I've found using a combination of grade 8 hex head bolts of different lengths along with a McMaster tool:
https://www.mcmaster.com/96349A305/ is easier for me because closing the tool shown is more awkward than using a small impact driver along with a single open end wrench
to set the plus nuts.
I'll add that guy's method can slightly deform the first few threads of the plus nut due the short engagement of the tool's threaded mandrel. My method involves initially using a bolt long enough to fully engage the plus nut's threads, draw it up until that bolt bottoms out. Change bolts to a shorter one and continue drawing the plus nut until its fully collapsed with a tight grip
I've been using that tool and my improvised method for just about 14 years now. The only failures are those I create myself.
Just another idea to consider..............
