Old 07-21-2021, 09:47 PM   #1
How to best close bolt holes in floor?
Hi all,
after removing the rear seats from my e350 passenger van, what is the best way to close the bolt holes in the bottom before putting in insulation and flooring?
Mushin is offline   Reply With Quote
Old 07-21-2021, 10:19 PM   #2
larrie's Avatar
I found got bolts that matched the original thread pitch and put those back in the holes with some anti seize on the threads.
Larrie
Visit my Patreon page: patreon.com/LarrieEasterly
Old 07-21-2021, 10:39 PM   #3
I plugged the holes with plugs from a sheet of 1/8" ABS and then painted over with POR-15.
I happened to have a grommet installation kit and it has a hole punches that I size for the plugs.
A cut-off bolt will work also but just a lot more work.
Old 07-22-2021, 06:42 AM   #4
I used 12mm set screws with some RTV on the threads as seen in post 57 here:
https://www.sportsmobileforum.com/fo...p-10808-6.html
2000 KTM 200 EXC
Old 07-22-2021, 09:25 AM   #5
I used “Christmas tree fasteners” that are easily removable and pretty flush on top. Like this but I don’t remember the exact size.
Chico is offline   Reply With Quote
Old 07-22-2021, 09:29 AM   #6
Attachment 40870
It was a bear to get all my screws out . I had to use an impact wrench and work several back and forth which is why I did not want to put anything metal back in the holes
Tags
body, floor, holes
