Old 07-31-2024, 09:24 AM   #1
Interior update - Sound deadening & Panel refinishing
Hi all. Recently completed another project on my '93 E250. This place has been a great resource so I thought I'd share this nice improvement.
I'm upgrading the stereo system which snowballed into a few different things. The plastic panels were in good shape but badly sun bleached into a weird yellow color. I had thought about a few different options of refinishing them but settled on painting them. Faster, cheaper, easy to touch up, etc. Process went as follows:
Wash with soap/water.
Acetone wipe
Alcohol wipe
Two coats SEM 39863 Plastic adhesion promoter
Three light coats SEM 15393 med gray color coat
Then as I was screwing plastic into plastic into sheet metal (thanks Ford), I thought "gosh, this is only going to rattle like crazy even more than it already does." So I decided I was going to line all six doors with sound deadening. I ordered the "Kilmat" self-adhesive 80 mil butyl & foil sound deadening sheets. This stuff:
https://www.amazon.com/dp/B0751CBXBT...roduct_details
Did all six doors with plenty leftover.
Results so far:
Very happy with the finish of the paint. Stood up well to the first outing and seems quite scratch resistant.
Even happier with the noise reduction from the sound deadening. Wish I had a better way of measuring it, but for me it's a very worthwhile investment. Cost was reasonable and the execution was quite easy.
Pics below of the process.
edit - well it rotated the photos for some reason but you get the idea. Gotta love tech.
20240710_150852.jpg   20240717_141511.jpg   20240717_160321.jpg   20240711_202852.jpg   20240723_142630.jpg
Keith is offline   Reply With Quote
Old 07-31-2024, 10:42 AM   #2
I measured my "sound deadening" efforts by downloading the "dB sound detector" app to my iPhone - and tested before and after install - with windows up - and found about 20% - 30% positive reduction. If already installed on the Kilmat - too late for you -
Old 07-31-2024, 01:22 PM   #3
That matches up with my ballpark estimation. Has me motivated to add more to the doghouse and other spots.
Old 07-31-2024, 03:29 PM   #4
My dog house has a lot of insulation already on the inside from factory (2014 e350 build).
So you just add more on top of what's there? It's in good shape and pretty thick...and I'm cautious about putting more stuff so close to engine...
Nice job on the panel painting OP!
Ace944gs is offline   Reply With Quote
Old 07-31-2024, 03:40 PM   #5
I'm guessing my '93 isn't as robust, but only had it off once last year and don't recall. If I were to do it, I'd take off the factory insulation, line it with the Kilmat and then reinstall the factory insulation. Might just be something that needs some spot improvements. TBD on all that.
Old 07-31-2024, 08:46 PM   #6
Nice work. I did my floors but not the walls and doors. Sounds like a good idea.
coloradoup is offline   Reply With Quote
Old 07-31-2024, 10:23 PM   #7
The_Vermonster's Avatar
I did floors and walls/doors with Damplifier Pro, and stuffed the cavities with Thinsulate.
At 70mph It dropped the DB rating from 79 to 73. That doesn't sound like much but it's significant. It also significantly changed the pitch of the noises that can come through. So it's a much nicer ride.
The problem now is that I can tell the door seals need to be replaced. :/
The_Vermonster is offline   Reply With Quote
Old 08-01-2024, 12:34 AM   #8
On my short list. Thanks for sharing!
kbeefy is offline   Reply With Quote
Old 08-01-2024, 07:04 AM   #9
Although I also added doghouse sound deadening - I found thickness limited to "would the doghouse still attach" with the clips/mounting - or create a gap and not seal correctly - allowing both heat, exhaust, and noise to enter cab ? Had to add - then remove - until I found the right thickness - not sure if my V-10 versus a V-8 5.4 makes a diff in thickness ?
Old 08-01-2024, 01:29 PM   #10
geoffff's Avatar
79 to 73 is a very significant difference!
I should get some Thinsulite...
-- Geoff
2004 Sportsmobile RB50 4x4 (Ford V10)
2005 Sportsmobile EB50 UJoint 4x4 (Ford V10)
GIL
Manoel Brazil
Serenity
Makalu1
