Old 10-21-2021, 09:04 AM   #21
Mikerson's Avatar
Snake might be overkill, but maybe if you want to see it in place. You can get to the spike pretty easy by removing the plastic panel then pulling the two clusters of 3 bolts that hold the steel bracket that supports the panel. I think they take an 8mm socket.
Mikerson is offline   Reply With Quote
Old 10-21-2021, 10:09 AM   #22
YoTerryh's Avatar
off topic
Originally Posted by 86Scotty View Post
I have always assumed the same.
Wow, haven't heard 'turducken' in a few years.
Now I'm going completely off-topic, but I had to mention Cherpumple:
"A cherpumple is a holiday novelty dessert inspired by Turducken, where several different flavor pies are baked inside of several different flavors of cake, and then stacked together."
YoTerryH
2001 Ford Econoline E250
GTRV camper conversion
YoTerryh is offline   Reply With Quote
Old 10-24-2021, 10:57 AM   #23
I would use the snake camera to see what or how the part interfaces with all the lower dash trim pieces in place. I tend to run with nearly everything removed anyway and can say there's not much to see.
So the elusive part still is goes unidentified and its use/purpose equally mysterious.
Old 10-24-2021, 11:18 AM   #24
joefromsf's Avatar
Well, since the title of this thread is "Name that thing", I propose to name it "Vlad, the Impaler".
2012 E350 RB XLT Wagon, Agile 4x4, SMB penthouse
joefromsf is offline   Reply With Quote
Old 10-25-2021, 07:59 AM   #25
I'm in too then!
So it be said, so make it so!!
Old 10-25-2021, 09:05 AM   #26
Mikerson's Avatar
Ok…ok…I should have titled the thread, “Identify That Thing.”
I agree on the name though!
Old 10-25-2021, 11:29 AM   #27
racer_rr's Avatar
From the photos I agree its part of the driver knee crumple zone. An expensive waste of a welded part number....so from my couch... I'd even guess it was added as a last minute solution to failures during crash testing.
It also may serve as a vehicle disable "switch " as it pierces through the wiring harness during a heavy hit.
GTRV Ford Econoline 250 - 2006 - 5.4l
racer_rr is offline   Reply With Quote
Esme
Amy V
Road Roamer
Road Roamer
