Foam topper is not bad. Not a lot of seat time with it yet since the sky started falling after I bought it. Its firm but not bad. Queen size 5” lucid memory foam from Amazon. I think it was 100-120$. Good reviews on it.
Double goof. I had the bed built around the spare wrench so even if I had access don’t have access to the tool lower it. Hahahhahahahah. Anyone have a spare one laying around they want to let go.
Those collapsible rods if shipped would run a decent amount I'm guessing. Visiting almost any scrap yard should find these laying around ready for recycling. They tend to be almost identical across brands but of course checking the tang end would be highly advisable.
You can pop off the cone thing underneath (designed to guide the crank tool into the pulley slot) and just use a flat blade screwdriver. It’s a PITA but it works. I’ve done it.
I did it as well when I installed their spare tire mount. I was able to remove the little plastic guide cone and still access the tire winch. It’s been quite a few years since I did it so I don’t remember specifics, but I was able to do it without removing the bumper again.
That was going to be my reply as well. Take the plastic glide sleeve off and you'll be able to figure it out on your own.
