Old 04-30-2013, 12:04 AM   #21
ANZAC's Avatar
Re: Suspension/lift
Originally Posted by Guitarvan
NV 3C24-5310-NA If i remember correctly "5310" is a generic test load for almost all Ford springs.
5310 looks more like a "basic number" for a Ford part.
Sportsmobile-less.
Old 05-02-2013, 12:56 PM   #22
BajaSportsmobile's Avatar
Re: Suspension/lift
Just a note: Caster is adjusted with the same eccentric that camber is adjusted with - you end up getting the best compromise of the two with the best eccentric choice you have. You have come this far on your own - bust out the tape measure and a friend and set your own toe.
Good job!
The vehicle still needs to go to the alignment shop for toe and caster adjustments but now its less that a hundred bucks and not $370 as one shop quoted.
AgileOffRoad.com
Old 05-04-2013, 03:01 PM   #23
Guitarvan's Avatar
Re: Suspension/lift
Good job!
Thanks, I think I will set the toe myself just to save another 80 -100 bucks and put that towards some more goodies. Thanks, again for the encouragement
2006 E350 XLT, Ultra Wheels Rogue 175 16x8, Toyo Open Country A/T 265/75-16. MAXX Lift 2" leveling kit
Guitarvan is offline   Reply With Quote
Old 12-30-2013, 10:31 PM   #24
Re: Suspension/lift
would like to pass along to anyone interested in lifting their home grown adventure vehicle, that I had a great experience (and very happy with) my Action Van lift kit. Larry was super helpful and knew everything about the modification of my vehicle. I had it done at the local 4 wheel parts store and relied on Larry's advice for the wheel size, offset, tire size, etc. Also bought Aluminumess ladder and spare tire carrier. Will have the ARB locker installed next. Half the cost of converting to 4x (would have loved to, but comes down to $).
Highly recommend if you are considering.
FYI.
You can see the transformation from my pictures dwest on the forum.
Dave
dwest is offline   Reply With Quote
Old 01-06-2015, 12:31 AM   #25
Re: Suspension/lift
Dest can you tell me how the alignment went on your van after your lift.
Thanks Bob
Gootjr is offline   Reply With Quote
Old 01-09-2015, 06:40 PM   #26
Re: Suspension/lift
Yes please do tell. Am trying to decide on Moog springs or Maxx lift kit.
chavez is offline   Reply With Quote
Old 01-17-2015, 08:31 PM   #27
Re: Suspension/lift
Great thread am also in 2wd 2002 e250 2inch lift zone.
My front axle is listed as GAWR 3700lbs my rear is GAWR 4265lbs
I am thinking of getting Moog 880S springs(progressive)
here are the specs for these springs
I am chef not truck guy so I am wondering what you guys that know think about these springs??
Moog 880S
"Bar Diameter - Inches 0.81
End Type 1 Pigtail
End Type 2 Pigtail
Feature Proper ride height reduces downtime and repair costs.
Free Height - Inches 16.60
ID - Inches 4.00
Installation Height - Inches 12.00
Load - lbs 3006.00
Spring Rate - lbs per inch 652.00
Spring Type Variable Rate"
Ford e250 Traverse
GTDad is offline   Reply With Quote
Old 12-02-2015, 08:14 AM   #28
Re: Suspension/lift
Here are some spring options:
Ramsey,
Ignorant question. How do spring loads correlate? It is weird, to me at least, that there a bunch of spring options with a load of 1500-1850 then there is the cc880s with a load almost double yet they are for the similar application.
I have a 2006 E250 with the 5310# springs a pop top and a medium weight interior build adding up the weights (I don't have actual weights but we semi frequently hit the bump stops).
I installed the cc880s and it gave just under 2" lift (1" or less would be preferred) and is stiffer than before. We liked the ride of the stock springs just don't want to bottom out, so I was considering the cc880 option, but just curious if that will be a flimsy noodle with a load rating of 1850
Federal mogul comes up with part numbers MOOG cc81368 and cc81370 as variable rate stock replacements but doesn't have load or spring rate specs and has an installed height of 6.784" (that seems a bit short). Nor do those numbers appear on moogs 18 pages of spring tables.....
Mariachi29 is offline   Reply With Quote
Old 12-02-2015, 08:28 PM   #29
Re: Suspension/lift
If you measure your installed length, you can do the math and see where another spring should end up.
AgileOffRoad.com
Old 11-19-2016, 01:31 AM   #30
winmag4582001's Avatar
Did the 2" Maxx leveling on my 2010. Very easy install. Rides better than before and looks better.
Figured I'd post the video here also for anyone going to do this project. Total time to do was about 2hrs and 4 beers. I installed coilover rear shocks(Monroe from O'rielys) that added maybe an 1" to the rear ride height.
2017 Subaru Legacy
1990 Volvo 240GL
2x 1987 BMW 535is
1995 BMW 540i6
winmag4582001 is offline   Reply With Quote
Rosy
Isever
Agnes
ranchero
