Old 04-10-2013, 05:38 AM   #21
Re: Hitch Motorcycle carrier feedback please
Roonie
can you measure from your tray to hitch pin?
What I've determined is that I am approx 33" from hitch pin to center of carrier tray ideally.
This does not take into account the fact that once a bike is on the carrier, the handlebars (which will face drivers side) may in fact be "over" the spare tire. This may allow me to move even closer.
The Versa Haul double rack can be ordered with just a single tray, and you can also "adjust" the tray in or out which I like.
My thought is to go with this set up and adjust in the tray as far as possible.
This allows me to use no extension and still clear the rear galley box/tire.
carl
2010 SMB
Old 04-10-2013, 12:05 PM   #22
Roonie's Avatar
My handlebars hit my spare tire and that is before compressing the front forks to tie it down with ratchet straps to the carrier. This is with the 14" extension. The spare is a 34" tire.
Old 04-10-2013, 01:35 PM   #23
I really like the size and height of MX Hauler style. You've had both.
what is the best set up in your opinion?
carl
2010 SMB
Old 04-10-2013, 03:33 PM   #24
Is anyone using a "second" hitch box? I found some using "outriggers" or an extension going into each frame mounted hitch receiver. Main location and adding two additional receivers, one per side. I am referring to two with the second mounted right below the stock one.
thoughts?
carl
2010 SMB
Old 04-10-2013, 06:48 PM   #25
LeadDoggy's Avatar
Originally Posted by sdwindansea
There was someone on this forum who fabricated a setup with two rear hitch receivers (instead of a single one in the middle) for their motorcycle carrier. Looked really stable and was a great idea. You can probably find the post if you search around a bit.
07 E350, Custom and Lifted
09 KTM EXC 530
Old 04-11-2013, 12:27 AM   #26
Lots of great info and pics in this thread! I'm gonna fab something up so that mine isn't such a Piece of Crap.
2006 Express Duramax 2500
Spoolin is offline   Reply With Quote
Old 04-11-2013, 01:14 AM   #27
NRL
NRL's Avatar
Send a message via Yahoo to NRL
Originally Posted by Spoolin
For those of you who have used motorcylce carriers, have any of you encountered or had any issues with the carrier wobbling? I'm wondering if it's just me who was having this issue.
Thanks
Check out my Buddies Tan Van, he had hitchcrafters weld up two parallel hitch hole brackets welded to the parallel frame beams, then fabed the two steel arms (slight angled with holes in the ends) that makes the platform, bought and cut the other two aluminum channel pieces that go on top.. The other forms the ramp. Where the bike wheels sit on..
It gets ratchedit down in squat mode .. Isn't going any where 4x4ing..
Wish I had a newer picture of it lately but his custom made steel rear bumper that got added with the two hitch holes..has a pass thru..Holes that reach the welded to the frame hitch hole brackets. You can make it out zooming in on the pic..
He's also got a brand new Texas SMB top custom made with a hatch in the middle with about 300watts of solar covering most of the whole penthouse top, you can bearly tell its there. Surpassing my setup.
I'll see if I can find newer pics, here is an older pic:
Pic of My hydralic carrier, survives mild 4x4ing far but you can see the bike twisting back there when you get on a trail on bumps and holes.. Surprised it still works..
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 04-11-2013, 10:47 AM   #28
vwteleman's Avatar
Gents,
This seems to be the definitive thread on MC carriers: Motorcycle Carriers
Includes a few examples using multiple receiver hitches, with lots of photos.
Cheers,
Brent
Old 04-11-2013, 12:05 PM   #29
xcnick's Avatar
I just happen to be working though this problem now. Although not as elegant as the other examples, my solution was a pretty simple bolt up. I bought receivers for 4" camper bumpers that bolt on. I used the Swagman because it has a bolt to reduce play. Then I just bolted it up to the receivers cross member. Between the anti sway for the rack and the second support and its bolt for anti sway the unit is pretty rock solid.
1996 Ford EB 2 wheel drive 460
xcnick is offline   Reply With Quote
Old 04-11-2013, 12:40 PM   #30
Roonie's Avatar
I like that solution. Simple and effective. Thanks for posting
