Old 08-02-2021, 09:47 PM   #11
Beware the limitations of your hitch receiver. You need a class 5 hitch to carry both.
FWIW - I sometimes do tow behind one of my hitch racks. But my receiver is rated for 6,000 pounds of tongue weight.
Old 08-03-2021, 05:07 AM   #12
I'd much rather not drag a trailer if I don't need to. The trailer in question though doesn't weigh much more than the dirt bike and prob carries about 80 lbs of tounge weight loaded. Was planning on carrying fire wood on the carrier. Not sure if that matters.
Vanguy is offline   Reply With Quote
Old 08-03-2021, 05:44 AM   #13
I'm really liking posplayer's solotion and will prob try to copy that with some slight mods.
Old 08-03-2021, 05:50 AM   #14
Also I might be better off trying to put some storage on that little one rail trailer than trying to double-up on the hitch.
Old 08-03-2021, 07:17 AM   #15
I do that as well when desirable. My motorcycle rack is a double. Usually only nine is take and the other tray is used for coolers and totes. Total weight limit of the rack is 800 pounds so it has ample capacity.
Old 08-03-2021, 11:30 AM   #16
gahamby's Avatar
6,000 pounds of tongue weight or towing capacity?
'07 GMC 2500 6.0
Old 08-03-2021, 12:19 PM   #17
Tongue weight. Towing capacity is 20k. It’s a Buckstop-Reunel bumper. Front end gets pretty light when you max it out though.
Old 08-03-2021, 12:47 PM   #18
gahamby's Avatar
6k of tongue weight sounds pretty hairy.
'07 GMC 2500 6.0
Old 08-03-2021, 01:07 PM   #19
I don’t tow that much regularly buts it’s pretty handy when I need it. Mostly it’s just nice being able to carry whatever on the hitch rack and not have to worry about it. Or have any extra movement. Note my van is a dually, otherwise the tires would be maxed out well before the hitch.
Old 08-04-2021, 10:22 AM   #20
gahamby's Avatar
That front end is up a little. Do you have to steer on the skip?
'07 GMC 2500 6.0
