2002 Sportsmobile V10 EB50 Quigley 4x4
Note: I'll update the thread with more pictures. I updated some info about the original build. EB50 is a very popular floorplan.
2002 EB50 Sportsmobile
6.8l V10 gasoline
Quigley 4WD
Odo: 49,100 2 owners
Exterior: Ford light parchment gold (“BQ”)
Interior: tan
EB50 layout
4cuft fridge
captain’s chairs, coffee table
16 gal fresh water, sink, propane hot water heater, outside shower
Gray water tank
Propane furnace
Thetford porta potty + leather cover (stores under sink)
Penthouse roof (electric) - photographer option (opening front panel)
4 FRS radios/charging dock built-in
Fiamma awning
Yakima Yak Trax and cross bars
XL Storage
Table
Fog lights
Outdoor shower (canopy and floor included)
The Good: New equipment/replacement/upgrades
• Complete front end rebuild by Quigley factory, upgraded front control arms and new Bilsteins all around (by PO 2011)
• Propane tank (by PO 2011)
• Husky front floor liners
• ATX Mojave wheels black/teflon (16 x 8 3100lb load rated) and BFG All-Terrain T/A KO E rated 285/75-16 tires (2011)
• Mag-Hytec D70 rear diff cover increased 6qt capacity w/ dipstick and LE-1605 Duolec SAE 110 gear oil (2011)
• Hella TC400 TPMS system (2011)
• Kenwood DNX6980 Nav/Entertainment system (w/ 2015 maps) & upgraded front speakers (2011)
• ScanGauge II (2011)
• Draw-Tite 41926 Class V hitch (2011)
• Cibie e-Code headlight upgrade, relays (2011)
• All incandescent house lights converted to LED, switchable white/red
• Transfer Flow 46 gal fuel tank - new tank is made of thicker material and has better anti-corrosion treatment than original TF tank (2012)
• Aluminess front and rear bumpers, w/ rear Galley box for Honda generator (2011)
• Warn M12000 winch and synthetic line with thimble (2011)
• Hella fog lights and reversing lights (2011)
• New side steps
• NEW Penthouse top by Sportsmobile West w/ Raptor Lining - PO had installed vent fan in Penthouse top, which caused cracks/leaking (2013)
• New 4D battery and awning brackets (2013)
• New propane, smoke detectors (2013)
• Xantrex LinkPRO battery monitor and battery temp sensor (2013)
• Deaver rear springs and new shackles (2013)
• 2 x 100W Zamp solar panels and 30 amp controller (2013)
• Stop-Tech Cryo-Sport slotted front rotors, Hawk Super Duty front pads, new front calipers and hoses, new Ford rear rotors, calipers, pads, parking brake cables (2014)
• aFe Power Magnum FORCE Performance Air Intake System (2014)
• Tekonsha Prodigy P2 Trailer Brake Controller (2014)
• Wilson Electronics - cell phone booster (2015)
• Serpentine belt, idler pulleys etc (2015)
• Suburban SW6D water heater (2016)
• Plugs, fuel filter, blower resistor+pigtail (2016)
The Bad and the Ugly
• Vehicle came from Michigan, so there is some lower van body rust in places (not structural, see pictures) – chassis has been almost completely painted with POR15 and is rock solid
• Starcool house AC no longer functional – though in-cabin pieces (evap, blower etc) are still there (vehicle AC works fine and blows very cold)
$59,900
Sportsmobile-less.
